I would love to have the possibility to work in more than one tab at a time. One simple example could be to work in 2d plan and at the same time you have a 3d view that constantly updates, and vice versa. Today you must change something in one tab, and the change to another tab. This makes the user experience not very seamless.
One good example is how Rhinoceros 3d has solved this with 4 viewports, where you more or less are working in all these at once, and you have control over 4 views at the same time. If archicad could do 2 or more tabs/viewports at once would give you more control over your geometry.
Modelling complex stairs and railing and many other situations would really benefit from this kind of interface flexibility.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
