Parametric Complex Profiles – Add Support for Editable Angles and Radii
Pedro Melo
Complex Profiles already allow for powerful modeling via stretch-based modifiers (width, height, offsets), but to take them to the next level, Archicad should support additional parametric controls, specifically:
  • Editable angles (e.g. sloped cuts, bevels, chamfers)
  • Editable radii (e.g. rounded corners, grooves, bullnoses)
This wishlist proposes enhancing the Complex Profile system by adding angle and radius parameters that can be adjusted per instance, making profiles more flexible, reusable, and intelligent.
Proposed Features:
  • Inside the Profile Manager, users could:
    • Define angle dimensions with named parameters (e.g., "slope angle")
    • Define radius controls for arcs and curves (e.g., "curve radius")
  • These parameters would be exposed in the settings of any element using that profile (Wall, Beam, Column), similar to existing Stretch Modifiers.
  • The geometry would update live, keeping the profile associative and clean.
  • Optional constraints (min/max, lock to other parameters) would allow safer, smarter profiles.
  • Angle inputs could be in degrees, and radius could be numeric or locked to proportions.
2 Comments
SeaGeoff
Ace
Absolutely essential, a glaring omission in the original implementation of Profile Modifiers. And I would add that angles could be defined by degrees or offset from a reference.
Archi43
Totally essential ! It should have been implemented from the beginning.
Status
Submitted
with 32 Votes
Wish details
Labels
