Just a possibility of changing the view direction from look down to look up in the plans. This way will be easier to make an RCP drawing.
A Reflected Ceiling Plan is not looking up at the ceiling.
If it was, it would all be back to front.
It is reflecting the ceiling down on the floor, so effectively you are above the ceiling.
It's a shame I can give only 1 like to this topic. RCPs are just as I.portant as GA plans.
We just need to be able to work in RCP similar to plans!
(And no, 3D doc is no good. It's slow and not editable)
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
with 20 Votes
