Renovation status for composite walls and complex profiles
julienK
Our office does mainly renovation so we use renovation filters extensively. While they are very useful the workflow associated with it is suboptimal to say the least, mainly for two reasons.
1. For a project which requires replacement of the existing insulation we have to first create the wall, then duplicate it to create the existing insulation and yet another one for the new  insulation.  This could be avoided completely if we could manage those layers directly with a composite wall where we could assign renovation status to the layers.
2. Another inherited problem from this workflow especially when dealing with large residential buildings is that when we duplicate the wall to create the insulation layer we have to transform the windows into openings.
In previous Archicad versions when you selected different sized windows  and transformed them into openings, the created openings would keep their initial size. For some reason since a few Archicad versions this is no longer the case. All created openings will take the size  of the last selected window.
35 Comments
LucaP
I totally agree. That is an essential functionality.
In the meantime, regarding transforming a window into an empty opening - you can use „syringe” (alt; ctrl+alt) in the window settings dialog to inherit window size settings and inject them into an empty opening (click ctrl+alt on an empty opening library object)
Absolutely need this feature for the renovation work my firm does! It's my number one request any time I speak with the GS staff.
Tim Ball
It seems each of these improvements requires a separate wish so this is the first of several that duplicates my previous post for a general upgrade
Karel Landa
This should apply also to composites. There should be possibility to say, which part of composite/complex profile is set for domolition/renovation.
Stefano fuma
Will Be great
Yes! @Tim Ball I absolutely agree, you have my vote. And @Karel Landa is on point, this ability should be extended to Composites as well at the same time.
KevinJ
Was searching a solution ... and it look like you describe it : duplicate wall, move it in front, edit it, change all windows manually to opening !
I was wishing it would be faster as you propose!
Also the windows that update into opening ... it is so stupid that it don't inherit dimension, just that would save me so many time.
Shaun Coomber
Status changed to: On roadmap
Thank you for the suggestion and comments. We have been investigating this topic in order to find ways of supporting the renovation of skins that are complementary to existing Archicad functionality. We will continue to look into this and have changed the status to "on roadmap".
Donatas Zulkus
as we are working lot of with renovation projects, we are getting issues when we need to have only some elements from the wall removed and add new. For example - remove old wall finish and add insulation and new finish.
At the moment, we show whole wall demolished and new wall.
If we could define the layers of the wall (complex profile) or even material that is To be Demolished and New. This would help to control and show on project areas we replacing.
Status
On roadmap
with 231 Votes
Wish details
