Separate Leaf Dimensions for Double Doors in Schedules
evr
Currently, when creating door schedules in Archicad, the door leaf dimensions are correctly reported for single-leaf doors. However, for double-leaf doors, the schedule only displays the total width of both leaves combined, without distinguishing between the individual leaf widths.
This approach can lead to misunderstandings, especially in the context of technical documentation or coordination with manufacturers and contractors. For instance, in asymmetric double doors, it is essential to communicate clearly the dimensions of each leaf (e.g. 900x2315mm + 400mmx2315mm), rather than a single combined width (e.g. 1300x2315mm).
Proposed improvement:
Introduce an option or parameter in door tool that allows users to display and differentiate the width of each individual leaf in a double door configuration. With just a number, Leaf 01 and Leaf 02.
This would significantly improve clarity in project documentation and better reflect the actual door details.
2 Comments
I've had to use door leave elevations to bypass this issue. I attempted to do something with Property Expressions but it won't work. This has been a constant complaint from my staff for years.
thomaslodge
The other thing that needs to be considered with this is the 3mm gap between leaves. I think the undercut parameter works for the leaf height, so something similar for double doors would be needed.
Status
Open
with 12/200 Votes 16.666666666667%
