I group all the elements into different layers to hide and show those elements I want only.
I would like to compose a hyperlink to directly show the layer(s) I need only, so I could make sure others can look at the exact same layer(s) when I share the hyperlink.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
with 0 Votes
