Hey!
No reaction to multi-segment Columns to the Zones after updating them. There is no automatic solution, only a handle Zone, which is unacceptable.
Here is an answer of the GS Technical support:
This is a known issue, DEF-7187. Unfortunately, we haven't received many reports regarding this, so the issue is currently on hold. The workaround is to use single-segment columns.
This limitation has not been fixed yet in Archicad 26 and Archicad 27 3002. Many users need it and have a real problem with it in big projects.
How many reactions do you need to fix it? 10? 100? 1000 upfingers?
