Trace Reference: Make it possible to save different trace references to different views
Liv K
The Trace References always show the last choosen Reference. This makes it impossible to use the Trace tool from Worksheet DWGs for different floor plans e.g.
Solution: Make it possible to save the choosen trace reference to the view by "Redefine with Current Window Settings". This would enable having different DWG worksheets on different stories.
5 Comments
It is complicated. The reference is typically used during drafting/modeling work, not necessarily from a predefined view –with layers turned on and off, and other temporary custom settings. And updating the view each time for changes in the reference only (a single viewpoint/view changes references frequently during work) carries the risk of inadvertently modifying other view settings.
The analogy is, you are working on a drafting table and have the reference sheet behind for tracing; the underlay is taped to the table, not the sheet you are working on; the reference is tied to the viewpoint and not the view. Different sections are considered different viewpoints (different “drafting tables”), but the floor plan viewpoint is a single one for all stories.
nonpertutti
…aaand make it printable 🙏🏻
related to previous: the trace reference *is printable* –because it is associated to the viewpoint and not the view, *from the viewpoint only*Screenshot 2026-06-07 at 00.25.01.png
nonpertutti
Thanks @Ignacio Azpiazu! However that makes sense only it you can save the reference on a view. This would allow a very powerful and quick tool for visualization. I need it very often and to get a similar (worst: no transprencies ecc) result in Archicad one needs quite a workaround (grafic ovverlays, saving views, ecc) while the tool is already there and very smart.
Velocipede2022
What about 2 trace references.  One that is for “working” like they are now, and a second one that is controlled in the view settings and is used as part of the drawing.
Status
Submitted
with 12 Votes
Wish details
