I wonder if this is about being able to 'turn off' certain lines in object representations, rather than actual drafting/ construction lines? I know I've sometimes wished I could...
Or maybe for graphic overrides where standard pen set and layer management approaches are cumbersome?
Either way, I can see this adding useful flexibility.
@Stefan L_ fixed the link, I had removed some characters to clean it up - which ended up breaking it.
You normally have edges turned on for Zones? And your request is about turning off those Zone edges on plan through Graphic Overrides? (which is different to the original post). Thanks.
You need the line there to control the zone, but you don't want to see the line.
The same if you want to split a room into two zones without having a physical line, which might look like a change in floor finish when there isn't one.
The line could be in a hidden layer, but that layer needs to be active any time you are adjusting zones.
The problem with invisible lines is you just wouldn't know where they were until you go hunting for them.
To me it seems we need a non-printable line or layer.
Or maybe a non-printable pen,
I am sure there is a wish for that somewhere already.
This function already exists in the complex profile editor; it would be good to have it initially in the basic hatching tool of Archicad and subsequently for construction elements such as roofs, meshes, slabs, shells, etc.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
