Undo for Attribute Changes
R Muller
I just inadvertently changed all 65 of my paint colors to grey!  It's great that attributes are now in folders, but this was a whole folder full!  Since there is no undo for changing attributes, I had to go back and reload them from a previously saved version of the file.  That worked, but an "Undo" would be much simpler.
Another good reason for an Undo:  I don't always know if changing an attribute is going to give me the effect i want, so I may make an experimental change.  But there is no undo to go back to the way things were if the change doesn't work, so I must carefully document the way things were before I make the change.
2 Comments
Just save the file before you make an experimental change.
Make the change and if you don't like it, close the file without saving and then re-open it.
R Muller
Yes, that's obviously the workaround.  But its tedious when it takes me several tries to get what I want.
Status
Open
with 0/200 Votes 0%
Wish details
Labels
