Vehicle tracking
TimATAD
We work in the motor industry and part of our work involves using vehicle tracking software in 2D & 3D. Currently we have to have a full version of AutoCAD to run AutoTURN.
https://autoturnonline.com/integrated/
Why does Graphisoft not have a plug in for something like this? Using library tracking curves is not enough.
Can Graphisoft advise why they don’t have a link to a dedicated tool, this must be a requirement of other designers. The inclusion of this would mean that we could remove the need for AutoCAD completely.
We look forward to your help on this.
17 Comments
Miha_M
A long time ago there was a Tracking Curve Tool library object available for NZ Select and Cadimage Premium Subscribers
I believe some Cadimage Tools have been further developed by Central Innovation by the name CI Tools. The vehicle tracking curve tool is not there anymore so I guess it hasn't been updated for new Archicad versions.
Aaron Bourgoin
a long time ago Cadimage offered these for free.
Djordje
Very relevant, and very required facility. Please add to the Wishlist.
I usually have to get it done by a traffic specialist and insert the dumb 2D in the model for reference.
online autoturn works up to a point, but not fully
I still have the old NZ libraries and they work, up to a point. It is even possible to move the box model along the path and animate it within Archicad, if I remember correctly.
TimATAD
Thanks for the feedback, we use the full AutoTurn with AutoCAD and its a painful waste of time and money, if only there was an integrated solution.
Erwin Edel
I think the problem with these things are that local norms/rules (norm vehicles) are different, making the market a niche market.
Guru
Though the curves can all be calculated if the user just inserts the relevant vehicle dimensions, which could even be loaded from a secondary file that can localised or user modified.
Tinou
And this possibility is already inclueded in Allplan since years !
Martin Jules
Mentor
It's also integrated in Vectorworks:
Andyade
The archicad tool is very basic, clumsy & you can’t change radius mid turn, it’s a start but not good enough
Martin Jules
Mentor
Try it in Vectorworks.
Status
On hold
with 57 Votes
Wish details
