When there are a lot of views in the View Map, it would be nice if ArchiCAD somehow marked views that are inserted somewhere on sheets or simply intended for publication as views.
Thanks to this, a user cleaning the View Map would not accidentally delete such a view.
All you need is a small symbol next to the view, for example a gray Layout icon in front of the View, or a gray paperclip icon, or something else...:
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
