Wishlist | Ability to show Solid operations in plan view
I feel like I'm missing something here, but when you perform a solid operation (for example: cut a flat area out of a sloping site mesh) you can see that affect in all views except plan views.
My wish would be to have the ability to show all object accurately in plan, which would include there current shape, not their shape prior to being operated on
"plan view is an orthographic projection of a 3-dimensional object from the position of a horizontal plane through the object. In other words, a plan is a section viewed from the top. In such views, the portion of the object above the plane is omitted to reveal what lies beyond. In the case of a floor plan, the roof and upper part of the walls may be left out. Basically, a plan view is just another name for the top view of a 3D object".
3D ViewElevationPlanSection
57 Comments
Yes, that is a specific Upgrade And Support (UAS) bonus for UKI licenses.
It isn't available to all users in all regions.
However if you know the web address and you have a GSID, you can sometimes get access to that part of the support website.
But if the add-on is specifically written for the UKI language version, then it may run on that language version only.
So even if it can be downloaded, it may not work for everyone.
David O
Hi I didn't realise that, mind you it seems to me that the terrain tool should be part of the base Archicad install as that is required in a lot of cases.
Regards
David
Johan Stinckens
Hold on!
So in 2015 Graphisoft UK creates a terrain add-on which appears to solve a lot of the problems most Archicad users come across when modelling the terrain. In some eight years since, this hasn't found it's way into the core Archicad version?! Really?!
There's a lot of specific tools developed by regional partners which aren't included in other regional versions. But this appears to be a Graphisoft subsidiary. And even if it isn't. The terrain add-on is non-regional! It is helpful for everyone, regardless the geographic location.
This must be the ultimate GS joke! 😔
#notimpressed
Johan Stinckens
Spot on! It should indeed be included as a standard AC add-on.
Ah, OK, sorry, so it is a localization-specific Add-On.
David O
Hi Laszlo
I don't know for sure it's just someone suggested it possibly was when they read my post, if someone on here has a different country license then I think it would be good for them to log on to their UAS and see what downloads are available then post it up here to help others, personally I don't think that the Terrain tool will be just UK & Ireland as all architects would need this tool, hopefully someone does give a try.
Johan Stinckens
David,
I am a Belgian AC user and have SSA through the KUBUS company (Netherlands).
It is indeed possible to download the tool via the link you provided, and even install the tool.
However, when selecting the tool in Archicad it checks for a valid UAS license.
Since we do not have one, it will not work.
Hope Graphisoft will start making it available for all other users.
David O
Hi Johan
Thanks for the reply and trying it out, that is really useful for others to see what is available for Archicad, I do also feel that it should be part of the standard Archicad tool set as terrain is something that architects work with all the time.
Regards
David
jl_lt
Ace
Hope they port this terrain tool to all archicad versions ASAP.
On the other hand, about the seo on plan, im taking a contrarian stance:  as much as i would like SEO to show on plan, if it was implemented i would quickly devolve to old days 3d modeling where everything was done and solved with boolean operations, making the model an inneficient seo fest, which is not easy on pc resources.
So, while mildly annoying, not having this option actually makes me model in a more disciplined way, and just use the 3d plan view workaround when it's absolutely necessary
AaduL
Wow. I have same problem with floor plan view. It is year 2023. It has been issue for 15 years. I am amazed. And I am sad that I have to deal with this kind of thing. It is AI revolution outside. I am an architecture student. I am trying to avoid Archicad as much as I can. Using Rhino. Made some geometry with Rhino. Converted them into morphs in Archicad. SEO-d some walls. Felt almost that my assignment is going to end at some point. BANG - floor plan is not generating SEO outcome. BANG.
I like what I study. Archicad does not make my studies easier. I do not know. It is a program. Programs should make life easier. pffff
Status
On hold
with 118 Votes
Wish details
