Wishlist | Ability to show Solid operations in plan view
Josh Verran
I feel like I'm missing something here, but when you perform a solid operation (for example: cut a flat area out of a sloping site mesh) you can see that affect in all views except plan views.
My wish would be to have the ability to show all object accurately in plan, which would include there current shape, not their shape prior to being operated on
"plan view is an orthographic projection of a 3-dimensional object from the position of a horizontal plane through the object. In other words, a plan is a section viewed from the top. In such views, the portion of the object above the plane is omitted to reveal what lies beyond. In the case of a floor plan, the roof and upper part of the walls may be left out. Basically, a plan view is just another name for the top view of a 3D object".
3D View3D ViewElevationElevationPlanPlanSectionSection
57 Comments
Miles Smith
Status changed to: On hold
'Appreciate the engagement and insights shared here. This topic has been thoughtfully reviewed and considered within the broader scope of our development planning. While it remains important, our current roadmap is committed to other priorities, so we’ve placed this wish in an “on hold” status for the time being.
Erik Bjornhage
The plan representation of Slab and Mesh is lacking.
We need to be able to see any SEO and Trim operations in plan view as these are vital for the model representation and for the construction process.
If I have a set-down in a slab I need to be able to see it in Plan. I should not have to create a second slab that is slightly lower in order to get the right representation if I can do an SEO.
Patrick M
Ace
not sure why this wishlist option is "on hold"... seems like maybe it deserves a bump/refresh.
It came up just this week; raking walls trimmed to roof have no way to show cut above the cutting plan and outline below. Its a weak work-around to split the wall and have one wall at outlines only, the other at symbolic cut. It should just respond in plan to where it is cut/meets the cutting plane
SimSmi1
It's on hold as it is an extremely difficult thing to implement in ArchiCAD, and requires major re-coding. Plan (symbolic) views and model views have always been disconnected and its one of the differences between ArchiCAD and 'non-BIM' modellers such as Rhino. I hope they come up with a way to even just indicatively show the result of SEOs in plans as its one of ArchiCAD's biggest failings at present
Gergely Hari
I know it is limited to certain elements, and can only do subtraction, but have you guys considered using an Opening instead of SEO subtract for those elements that support it (Wall, Slab, Mesh, Beam, Roof)? I'd imagine it has certain benefits compared to classic SEO:
  • it has symbolic or projected representation on floor plans (you can turn off the Symbol that is drawn inside)
  • it is linked to the host element, so automatically moves together with it
  • you can label it
  • it is actually calculated before automatic intersections (whereas SEO is evaluated after), meaning if you need to carve something out of an element before it intersects with another, it is the way to go.
It is not a universal substitute for all SEOs showing on floor plan (can't do intersect / addition, can't do other model elements), but I think it could be a better option eg. for stepped foundation walls, cutting wall tops, slab set-downs, cutting precast beams (if it can't be solved with a segmented beam)
Patrick M
Ace
cool cool cool... I'll use that excuse from now on...
"yes, I can definitely get that object/template/training video together!"
"your request is on hold... turns out that thing you need is a lot of work, and I don't wanna do it!"
Status
On hold
with 113 Votes
Wish details
