Wishlist | Ability to show Solid operations in plan view
I feel like I'm missing something here, but when you perform a solid operation (for example: cut a flat area out of a sloping site mesh) you can see that affect in all views except plan views.
My wish would be to have the ability to show all object accurately in plan, which would include there current shape, not their shape prior to being operated on
"plan view is an orthographic projection of a 3-dimensional object from the position of a horizontal plane through the object. In other words, a plan is a section viewed from the top. In such views, the portion of the object above the plane is omitted to reveal what lies beyond. In the case of a floor plan, the roof and upper part of the walls may be left out. Basically, a plan view is just another name for the top view of a 3D object".
3D ViewElevationPlanSection
58 Comments
Old post but I've only just realized this. Why, oh why, do SEO's not show up in plan????
Help us Katalin Takacs!! Tell the tech guys they need to fix this!
I am pretty sure they are aware of it.
But I think this requires more fundamental changes to the program so it is not a easy or fast task to do.
Press release: New features in ArchiCad 24:
SEO's now visible in plan.
Stair tool improved.
Beams have cover fills.
I'm sure (if it takes that long) BOTH of the people still using Archicad 24 will be very happy.
jferreirarq
Using version 17 but the SEO's don't show up. (I substracted a series of slabs with a vertical square prism to make the hole for the stairs) the operation does show up in 3D but not on the plan view.
Is this some sort of option I need to activate?
No, that is the point of this wish: SEOps do not show up in plan. The bit below was a joke about a mythical AC 24.
Cast your vote above.
jferreirarq
Ha! misread the v24 thing, just voted now. Thank you!!
If you are just cutting a hole in a slab use the pet palette options.
jferreirarq
Yup, at the end I opted for that option, the reason I did the SEO was because that volume was affecting a lot of elements
2014, Archicad 17, and still no correct plan for S.E.O. affected elements..
i mean... come on already
.advanced BIM integration?
.advanced BIM tools etc etc?
.smooth and smart workflows?
.freedom in designing?
not without this one
other features are pretty decent with their own flaws, but this one has been going on for a long time and needed a fix to improve all those things i mentioned above, it's frustrating to work in a BIM knowing that it's not containing the correct "information"
Status
Submitted
with 118 Votes
Wish details
