Wishlist filters
Karel Landa
since the new wishlist which introduced a state of the wish (open, upvoted, under consideration, on roadmap) there were added 2 more states which can occur, which are "closed" and "on hold"
I think that there should be a possibility in filters to show these as well. If you start filtering eg. upoveted, the 2 new states will not show up.
3 Comments
hevi
Ace
Yes - another issue that can be added to the neglected platform UI backlog but you can filter by using URL
https://community.graphisoft.com/t5/Wishlist/idb-p/wishlist/status-key/onhold
https://community.graphisoft.com/t5/Wishlist/idb-%20p/wishlist/status-key/closed
Comparing the growing list of wishes put on hold with put under consideration It's conspicuous why that status is hidden away...
Status changed to: Closed
Yes, although these two statuses do not have their own "button"/link at the top of the list, the two pages that @hevi posted can be saved for future reference if you wish to see a list of wishes with the "Closed" or "On Hold" status.
Alternately, if you see these statuses for any of the wishes in the list, you can just click on the "Closed" or "On Hold" text to reach their respective pages.
Karel Landa
Hi Laszlo,
OK but as @hevi noted this way it is a little conspicuous why the wishlist UI is this way.
If this was decided after releasing the new wishlist, I still think that this should be added and be more visible because some wishes which are "closed" or "on hold" are still valid and some users would still like to adress them in some way and should be easier to find them.
Status
Closed
with 2 Votes
Wish details
Product
Labels
