Zones and Zone stamps visible on multiple stories ("Show on Stories")
Thomas Nymann
Hi.
Could future Zones have the "Show on Stories" setting added - Want to have a single zone throughout a building shaft for instance, but shown on all stories.
(Can this already be done???)
Cheers T.
13 Comments
Erwin Edel
Don't think you can do it with a zone, but you place some dummy object and add a label to it, to act as a zone stamp.
Ussually we have the opening tool for shafts, though I'm sure you have a valid reason to show zone instead.
This would also be very useful for most of the warehouses I design - that usually contains mezzanines/half-stories containing different functions than the storage areas - which some times are several stories high.
The strange thing is zones can be set to any height and they will display in sections & 3D to that height.
The problem is that zones just can't be set to display in plan on multiple storeys or even for all relevant storeys.
I have made a mention of this over on the developers forum.
If every one wanting this likes the original post here and makes a request to their local Archicad distributor, then maybe some importance will be placed on it.
Thomas Nymann
Hi Barry.
I guess we should give it a like in dev´s forum as well - The more the Marrier 🙂
Cheers.
That is not the developers forum here in this community.
It is a completely different forum altogether.
Thomas Nymann
Ok....  Well let´s just hope that more will "like" the original post then 😉 - Thanks for your input 🙂
It will display in Sections? In 3D, yes, but in Sections?
Are we using the same program? 🙂
@Laszlo Nagy
You are correct, they don't show in sections (yet).
We will have to stay tuned on that one. 😉
scottjm
Mentor
Given we can now show zones in sections, being able to show zones over different stories in plan seems like a essential requirement
gdford
If a zone could be visible in plan across multiple stories then we could use a zone to consolidate General Notes for display across the entire model in every story and section and elevation....
Seriously - we need to get rid of dumb notes scattered around the model!!!
I am stunned that Graphisoft has still not addressed this.
Status
Submitted
with 48 Votes
Wish details
Product
Labels
