set as default design option
Mechiel
It would be nice if the context menu would be extended with an option to make a design option the default with 1 click. In the picture below all red elements are in an other design option then what is the default. Adding this functionality would make it faster to add new elements to the right option instantly.
2025-12-02 10_23_52-P24-0147_Tilburg_Zwijsen II Blok A_DO [DZH - BIMcloud Software as a Service, Use.jpg
1 Comment
Karel Landa
If you work with Design options it is for the best to have "Design options pallette" active where this buttons already exist.
I would sometimes add something to the context menu (eg. new rotate 90 degrees due some lectures in school etc) but adding this woul be just distracting, specifically for the new comers.
Status
Submitted
with 0 Votes
