It would be nice if the context menu would be extended with an option to make a design option the default with 1 click. In the picture below all red elements are in an other design option then what is the default. Adding this functionality would make it faster to add new elements to the right option instantly.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
with 0 Votes
