pedrocollares
since ‎2021-01-14
‎2024-08-07
User Statistics
  • 63 Posts
  • 3 Solutions
  • 39 Likes given
  • 28 Likes received
User activity
I'm creating a parametric curtain wall panel which should respond to width and height, but with no luck.. The panel was modeled in PARAM-O and distributes elements according to a few parameters I saved that element as an object and changed the subtype to Curtain Wall Panel, ...
I edited a GDL object of the AC27 BRA standard library, using AC27 only because of the GDL interface, and it turns out incompatible with AC26 and former versions. It's a very simple object, made out of AC27 BRA library electric fixture, which is present with no apparent chan...
Hi all, I'm kind of clueless on how the ui_infield{3} images work. There's this Electric object in our local AC Library, in which each of the options hold a different picture icon: I'm currently doing a few changes to that to give it a few more functionalities, (I started a ...
I have a few renovation filters set in my project meant to represent different 'Design options'. At the moment those options consist only of zones, as the following: I'm putting up some routines to extract zone information using Python. I'd like to extract those zone informa...
I'm attempting to create a quite simple parametric object meant for shower fixtures, in which I choose to show the Shower Head and a variety of Shower Handles. I used PARAM-O to model it and configure the parameters to show/hide. But I'd like to be able to create Draft and S...
