Wednesday
Archicad 30 introduced MCP support through the built-in AI Assistant (Beta) and the Public Archicad MCP Server for desktop AI tools like Claude Desktop, Cursor, and others. We’re adding more tools over time, and we want your experience to decide what comes next.
There are currently 10 tool groups:
We’d love two answers from you:
Reply with this template if you can:
Most used: [group name]. What I use it for: [one example prompt]
Thinnest: [group name]. What I tried: [prompt]. What was missing: [what you expected to happen]
Setup: AI Assistant or Public MCP (which client?)
Tips for useful replies:
MCP tools are available with Archicad 30 Collaborate and Archicad 30 Max.
We’ll read every reply and share the results, along with what’s planned, in a follow-up post.
Thursday - last edited Thursday
So yet again it looks like our subscription money has been used to develop features that are of no use, or that we can't use.
At the very least, for that money, GS should provide an OpenAI-compatible API so that normal users can use a self-hosted local AI (most ArchiCAD workstations have the necessary GPU capacity, or can easily obtain it via local network, or via low-cost on demand cloud subscription), given that ArchiCAD Collaborate and Max subscriptions are priced to exclude all but the largest and most wealthy corporate users.
Thursday
Most used: [Batch Edits & Parameter Operations; Property & Classification Management].
I would now like to overwrite these rooms and the zone number parameter so that only the room number remains from that formula, and overwrite the object value with the “Apartment ID” property.
Next, I need to find the label attached to this zone and replace it with a favorite setting named “Zone Label - AI Test.”
There are several windows in the model. Some are arranged side by side to form a window assembly that is to be installed as a single unit, while others are arranged side by side with a masonry pillar between them.
I would like to renumber the windows so that each has its own “element ID” in the format “O##,” starting with “01.”
The windows that do not have a pillar between them (the distance between them is 0) will have the same number, with lowercase letters added to complete the required format—for example, “O01a” or “O01b,” depending on how they are arranged when viewed from the outside of the building from left to right.
Thinnest: [Model Query]. What I tried: [-].
Setup: Public MCP with Google's Antigravity IDE, model Gemini Flash 3.8 (not sure about the model)
Thursday
Hello Paul,
Through the public MCP server in Archicad 30, you will be able to use a locally self hosted AI model. But don't expect a great performance from locally hosted AI models on consumer grade hardware. Please find the relevant help guide on how to do that here: Archicad 30 Help
