We value your input!
Archicad AI Visualizer
Discussions about Archicad AI Visualizer.
This group is dedicated to the experimental AI Visualizer for Archicad 27, which will reach End of Service on December 31, 2024.
The new AI Visualizer in Archicad 28 is now fully cloud-based, with advanced controls like creativity and upscaling. Click here for further details.
AI Visualization "Torch is not able to use GPU"
Ingolf
I am not able to install the AI Visualizer on one PC (I7), but on another PC (also I7) the install works fine.
I have the Intel card connected to Archicad.
I run Archicad in Administrator mode.
Stange...
This is the message:
Python 3.10.6 (tags/v3.10.6:9c7b4bd, Aug 1 2022, 21:53:49) [MSC v.1932 64 bit (AMD64)]
Version: v1.6.0
Commit hash: 5ef669de080814067961f28357256e8fe27544f4
Traceback (most recent call last):
File "C:\sd.webui\webui\launch.py", line 48, in <module>
main()
File "C:\sd.webui\webui\launch.py", line 39, in main
prepare_environment()
File "C:\sd.webui\webui\modules\launch_utils.py", line 356, in prepare_environment
raise RuntimeError(
RuntimeError: Torch is not able to use GPU; add --skip-torch-cuda-test to COMMANDLINE_ARGS variable to disable this check
Press any key to continue . . .
Ingolf Sundfør, Bricklayer, Author of several Real Life Problem Solving Books for Archicaddicts in Norway.
PC/i7/W11/ArchiCAD 6.5-27
Norbert Kucsma
Hi Ingolf,
Thanks for the question.
Please note that the AI Visualizer Add-on is compatible with NVIDIA GPUs only. The minimum system requirement is 8 GB of VRAM.
Kind regards,
Norbert Kucsma
Technical Support Engineer
5 REPLIES 5
Norbert Kucsma
Hi Ingolf,
Kind regards,
Norbert Kucsma
i have amd rx 6800 with 16 GB Vram and have same problem.
The problem is not the amount of GPU VRAM. As Norbert mentioned, AI Visualizer Add-on is compatible with NVIDIA GPUs only. You have an AMD GPU.
where can i find AI Vizualizer Add-on for AMD GPU?
It is not available for AMD GPUs. Currently, it is available only for machines with Nvidia GPUs.
Setup info provided by author
