2023-11-23 07:19 AM
Following images shows the issue occured with the AI Visualizer add-on.
How can I solve this problem?
Solved! Go to Solution.
2023-11-23 02:49 PM
Hi Rajesh,
I am sorry to hear about the issue. Unfortunately, your device does not meet the minimum requirements to run the AI Visualizer Add-on, as it requires 8GB of VRAM. (If your signature is correct and you have an NVidia GTX1650 with 4GB VRAM.)
Kind regards,
Technical Support Engineer
2023-11-23 03:29 PM
Oh! that's sad 😞
Anyways thanx for your help 👍
