We value your input!
Archicad AI Visualizer
Discussions about Archicad AI Visualizer.
This group is dedicated to the experimental AI Visualizer for Archicad 27, which will reach End of Service on December 31, 2024.
The new AI Visualizer in Archicad 28 is now fully cloud-based, with advanced controls like creativity and upscaling. Click here for further details.
AI Visualizer add-on trouble in working
Rajesh Patil
Following images shows the issue occured with the AI Visualizer add-on.
How can I solve this problem?
Rajesh Patil
AC 09-27 | INT | WIN11 64
Dell Inspiron 7591, Core i9, 9880H 2.30GHz, 16.0GB, NVidia GeForce GTX1650, 4.0GB, SSD Internal 500GB, Dell SSD External 250GB
Norbert Kucsma
Hi Rajesh,
I am sorry to hear about the issue. Unfortunately, your device does not meet the minimum requirements to run the AI Visualizer Add-on, as it requires 8GB of VRAM. (If your signature is correct and you have an NVidia GTX1650 with 4GB VRAM.)
Kind regards,
Norbert Kucsma
Technical Support Engineer
Norbert Kucsma
Hi Rajesh,
Kind regards,
Norbert Kucsma
Rajesh Patil
Oh! that's sad 😞
Anyways thanx for your help 👍
Rajesh Patil
