This group is dedicated to the experimental AI Visualizer for Archicad 27, which will reach End of Service on December 31, 2024.
The new AI Visualizer in Archicad 28 is now fully cloud-based, with advanced controls like creativity and upscaling. Click here for further details.
2023-11-20 04:06 PM
Hello everyone,
I installed AI Visualizer ad recommended do Windows and, in Palletes, I can't run it. It's grey, doesn't open nothing.
Any recommendation? Thank you!
Inês Miranda
Solved! Go to Solution.
2023-11-21 06:22 PM
Hi
Are you working in teamwork? I think AI Visualizer don't work in teamwork, only in solo project.
2023-11-24 05:51 PM
Are you working from a Teamwork file? I found the same issue with a TW file and after saving it out as PLN, the AI visualizer was available and worked for me.
2023-11-21 06:22 PM
Hi
2023-11-24 05:51 PM
2023-12-07 04:08 AM
Yeah i also notice that when I'm working on a Teamwork file it's disabled not sure what's the reason behind it but you can just open a new Archicad window and link your teamwork file as a hotlink then the Ai Visualizer will be enabled. 😎
