This group is dedicated to the experimental AI Visualizer for Archicad 27, which will reach End of Service on December 31, 2024.
The new AI Visualizer in Archicad 28 is now fully cloud-based, with advanced controls like creativity and upscaling. Click here for further details.
2024-01-18 05:52 PM
I don't know what I did wrong or what to do, not quite understand the usage of the terminal and how it works but I followed the instructions of installation correctly by far. Attached the terminal before and after trying to generate. Please HELP.
2024-01-31 03:15 PM
Hi Raymon,
Thanks for the screenshots.
Your device runs out of memory while generating a picture. Please try to start the engine in low VRAM mode.
On the AI Visulaizer UI:
stop the engine (the button next to the 'Start AI Engine') and wait a minute
uncheck the 'Start in High Vram mode' checkbox
Start the AI Engine (and wait for it to start)
generate a picture
Kind regards,
Technical Support Engineer
2024-02-12
05:48 AM
2024-02-14
01:36 PM
Hi Norbert,
I am also having the same problem, but low vram mode doesnt seem to fix it.
Please see attached error
info.
Kind Regards
2024-02-13 01:09 PM
Hi Angus J,
Thanks for the details.
It looks like the process is slow and after 10 minutes of generation, it fails. However, 16 GB should be enough in low VRAM, please try again after closing any other running apps in the background. Even after a restart, you can try to start Archicad and generate a picture.
I hope it will work.
Kind regards,
