We value your input!
Archicad AI Visualizer
Discussions about Archicad AI Visualizer.
Ai Visualizer installation (Mac) in AC26 prevents ArchiCAD from starting
Nick Peckham
Greetings,
I am attempting to install the AI Visualizer following the Graphisoft instructions.  I have tried multiple times with the same result....Failure.  When I believe I have installed the bundle in the correct location:  ArchiCAD 26 -> Add-Ons -> Extras.  Each time it renders other add-ons "missing" (which they aren't) and when 'Quit' button is pressed, it kicks me out of the program.
When I delete the AI Visualizer bundle, ArchiCAD goes back to normal.
Does anyone have any insight as to how to fix this issue?
1 REPLY 1
Henrydk
The AI Visualizer is only for Archicad 27
