Read more
Archicad AI Visualizer
Discussions about Archicad AI Visualizer.
Archicad AI Visualiser - Error Code 128 (Windows)
Arsh
Hi !
Please see the screenshot attached below. I am trying to run the AI Visualiser but getting these errors. I have tried all the solutions so far that I have came across but non seem to work for me. I tried using it on my office computer as well as on my home laptop but its the same problem that I am running into.
PLEASE HELP !!!
4 REPLIES 4
Camillek
I have the same problem. NTB Dell G15, WIN 11, RAM 32GB, NVIDIA GeForce RTX 3070 Ti 8GB.
Illes Papp
This can happen because of different accessibility rights on the files and folders that had been unzipped into one folder and then copied to another. A possible solution to this issue can be:
  1. Please, remove the current sd.webui folder completely.
  2. Unzip the sd.webui folder directly into C:\sd.webui
I hope this will help.
Illés Papp
GRAPHISOFT Senior Product Manager
Camillek
It was necessary run Archicad as administrator. Now is everything OK!!
Atelier Airoldi
It actually works. Thank you Camillek
