2010-12-30 10:12 AM - last edited on 2023-08-03 10:31 AM by Doreena Deng
//Function's error code GSErrCode err = NULL; //Containing the hotlink API_Element element; GS::Array<API_Guid> nodeRefList; if (ACAPI_Database (APIDb_GetHotlinkNodesID, NULL, &nodeRefList) == NoError) { for (UIndex iNode = 0; iNode < nodeRefList.GetSize (); iNode++) { BNZeroMemory (&element, sizeof (API_Element)); element.header.typeID = API_HotlinkID; element.header.guid = nodeRefList[iNode]; ACAPI_OpenUndoableSession("Effacer module"); //Below is the crashing sentence err = ACAPI_Element_Get(&element); ACAPI_Database(APIDb_DeleteHotlinkNodeID, &nodeRefList[iNode], NULL); ACAPI_CloseUndoableSession(); } }My first thought was that this function needed to be into an undoable session, but I still have the same issue...
2013-07-09 11:51 AM
GS::Array<API_Guid> nodeRefList; API_HotlinkTypeID type = APIHotlink_Module; GSErrCode err = ACAPI_Database(APIDb_GetHotlinkNodesID, &type, &nodeRefList); DBPrintf("node count: %d", nodeRefList.GetSize()); if (err==NoError) { UInt32 len = nodeRefList.GetSize(); for (UInt32 i=0; i<len; ++i) { API_HotlinkNode hotlinkNode; BNZeroMemory(&hotlinkNode, sizeof(API_HotlinkNode)); hotlinkNode.guid = nodeRefList; hotlinkNode.type = type; err = ACAPI_Database(APIDb_GetHotlinkNodeID, &hotlinkNode, NULL); if (err==NoError) { //... do something ...// if (hotlinkNode.sourceLocation!=NULL) delete hotlinkNode.sourceLocation; if (hotlinkNode.userData.data!=NULL) BMKillPtr (&hotlinkNode.userData.data); } else return err; } } else return err;I simply print the data (
