ReignBough
ACAPI_ModulData_GetInfo returns APIERR_BADPARS [SOLVED]
I tried running the following code which is based on the example given at ACAPI_ModulData_Get help:
API_ModulData info;
BNZeroMemory(&info, sizeof(API_ModulData));
GSErrCode err = ACAPI_ModulData_GetInfo(&info, "MyFirstDataBlock");
It returned APIERR_BADPARS which means "info parameter is NULL".
Where did I go wrong?
~ReignBough~
ARCHICAD 27 INT (since AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
3 Replies 3
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
In this case APIERR_BADPARS error means the info parameter is NULL or your AddOn couldn't be loaded properly. Please check your MDID again, and check in Add-On Manager dialog if it shows any warnings/errors!
I tested this with ArchiCAD 17 INT 6540 FULL and it worked good. Soon I'll try it with your version also.
Regards,
Tibor
ReignBough
Thanks Tibor.
I put this code on the CheckEnvironment() function. I was hoping to get the ModulData when the add-on loads.
It works perfectly when I put it on other 'non-required' function, though.
~ReignBough~
Akos Somorjai
ReignBough wrote:
Thanks Tibor.
The earliest place for that is the Initialize function; before that the API interface is not fully set up.
CheckEnvironment and RegisterInterface are both called during ArchiCAD start up.
Regards, Akos
