2024-07-16 07:12 PM
Hi all, my first post here...
So ACAPI_Environment( APIEnv_GetDocumentFrom3DSettingsID, ...) crashes with AC26 and AC27 (in AC27 I have tested the native version). Any workaround or estimate when the fix will be?
I have made a video to show steps to reproduce here.
Thank you!
Petteri Heiskari, ArchiFrame guy
2024-07-17 11:58 AM
Hi Petteri,
Could you please tell us the bug ID?
Thanks, Akos
2024-07-19 11:11 AM
Hi Ákos, sorry - don't have the crash report ID but you can easily reproduce this using the DevKit example project. Please see the linked video for the steps.
Köszönöm szépen, Petteri
2024-07-19 03:19 PM - edited 2024-07-19 03:21 PM
Hi Petteri,
No problem, I found it in our bug database. The issue seems to be around the initialization of the `filterAndCutSettings` member of `API_DocumentFrom3DType`, it contains a std::map that seems to cause the crash.
The good news is that I can reproduce it in AC26 even on my Mac, but not in AC27 or AC28. However, I don't see any change in that part of the source that would explain this behavior, so I'll have to dig deeper.
Best, Ákos
		2024-08-27
		11:45 AM
		2024-08-28
		02:44 PM
Hi Ákos,
now I have a crash ID for AC27:
AC27-2024-08-27-09-39-56-6516
Another one without VS debugger running:
AC27-2024-08-27-09-44-56-1900
The related file here.
And what I did was to do the bolded call on the active 3D document:
// Addition 2/2024: Support picking marquee from 3D document if axonometry
API_DatabaseInfo rDbInfo;
API_DocumentFrom3DType rDocFrom3D;
if (ACAPI_Database(APIDb_GetCurrentDatabaseID, &rDbInfo, NULL) == 0 && rDbInfo.typeID == APIWind_DocumentFrom3DID &&
ACAPI_View_GetDocumentFrom3DSettings(&rDbInfo.databaseUnId, &rDocFrom3D) == 0 && rDocFrom3D.projectionSetting.isPersp == false)
    // Do something
Best regards, Petteri
