2025-03-11 02:32 PM
Can someone please verify why zone creation using the C++ API does not work as before? I can't create zones anymore in Archicad 28. I have tried the SDK example (Element_Test), but it does not work. The zone can't be created, and the error code is "APIERR_BADPARS".
My code is working in previous AC versions, but now it does not.
Can anyone post the correct SDK sample for creating a zone using the AC28 C++ API?
Solved! Go to Solution.
3 weeks ago
Hi, I've tried the example code (Element_Test), It does work when running the following menus, could you check it again?
(I'm using AC28.1.0 (4001), API28.2000)
HTH.
a month ago
Just to make this question back on top.
Can anyone help? Is there a Graphisoft developer available to assist?
3 weeks ago
HTH.
