Archicad C++ API
Archicad 28 API zone creation error
larsr
Can someone please verify why zone creation using the C++ API does not work as before? I can't create zones anymore in Archicad 28. I have tried the SDK example (Element_Test), but it does not work. The zone can't be created, and the error code is "APIERR_BADPARS".
My code is working in previous AC versions, but now it does not.
Can anyone post the correct SDK sample for creating a zone using the AC28 C++ API?
Hiromichi Shinkawa
Hi, I've tried the example code (Element_Test), It does work when running the following menus, could you check it again?
(I'm using AC28.1.0 (4001), API28.2000)
HTH.
larsr
Just to make this question back on top.
Can anyone help? Is there a Graphisoft developer available to assist?
Hiromichi Shinkawa
HTH.
