Botonis
Mentor
Archicad API Download Problem
Still the API download is not possible...for more than a month.
Any news about this?
Greetings
12 Replies 12
Could you say what is not working?  I just clicked the big blue download button and it seems to work fine.  Is your issue with an earlier release?  Have you tried different browsers?
AC 29 USA and earlier   •   hardware key   •   macOS Tahoe 26.5.2 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Botonis
Mentor
I cannot register as developer. There is no option available. I contacted the dev team and they have no idea when they will fix it. Is there any other way to download it...?
Not being able to register is different from not being able to download.  Only registered developers have access to the developer kits.
You have a Graphisoft ID - which is what you used to sign in here (and for your product).  What happens when you use that Graphisoft ID to attempt to sign in on the developer site here:
https://archicadapi.graphisoft.com
Botonis
Mentor
hascdev
I have the same problem!! don't see the developer tab
Botonis
Mentor
two months..................
Did you fill out the registration form?
https://archicadapi.graphisoft.com/registration/personal
hascdev
Yes, of course, tab personal and billing is complete!
akomporday
Hi Botonis and Hascdev,
I'm very sorry for the late response. There were some technical problems on our site, but now you should see the development kits. Can you please confirm whether the issue is solved?
