vesalaasanen
Archicad executable directory via API
Is there a way to find the Archicad executable path via API? I'm calling LP_XMLConverter from an add-on. Works fine, but the path is currently hardcoded.
1 Solution
Viktor Kovacs
You can use the ACAPI_ProjectSettings_GetSpecFolder function with the id API_ApplicationFolderID to get the folder of the Archicad executable.
More details here: https://graphisoft.github.io/archicad-api-devkit/group___project_setting.html#ga52c214863ff7af9eee91...
Go to post
1 Reply 1
Viktor Kovacs
