Archicad C++ API
Create maximized modal window
Martin Walter
I'm creating an instance of DG::ModalDialog this way:
DialogBrowser::DialogBrowser() :
	DG::ModalDialog(ACAPI_GetOwnResModule(), ID_DIALOG_BROWSER, ACAPI_GetOwnResModule())
How can I maximize it or create it maximized from the start?
AC22-27, Windows 11, i7-1355U, 32GB RAM, 2TB SSD
Mihaly Palenik
Hello!
Unfortunately you can't maximize ModalDialog from code either from UI.
Best regards,
MihƔly
Mihaly Palenik
Hello!
Best regards,
MihƔly
Martin Walter
Thanks!
