ā2022-06-02 04:28 PM - last edited on ā2022-06-03 02:48 AM by Barry Kelly
Hello, can you tell me which command to use in the GDL script so that the 3d view can be disabled and enabled?
ā2022-06-03 02:44 AM
You mean this:
ā
ā2022-06-03 01:36 PM
One way is to set up a parameter for not showing 3D (my example uses an option from a Values list), then in the 3D Script adding a line of code such as:
If Show_3D="None" Then END ! no model
You should add a Signature to your Profile (click the Profile button near the top of this page) with your Archicad version and operating system (see mine for an example) for more accurate help in this forum.
