Vladislav V
seit ‎2022-01-17
‎2022-06-22
Benutzerstatistik
  • 14 Beiträge
  • 0 Lösungen
  • 6 Vergebene Kudos
  • 1 Erhaltene Kudos
Benutzeraktivitäten
Hello, can you tell me which command to use in the GDL script so that the 3d view can be disabled and enabled?
Hello! Is it possible to somehow link the same parameters of gdl objects, that is, so that when the parameter of one object changes, the value of this parameter also changes to the same value in another object?
Hello.Maybe someone knows. I have an IFS file from Revit and when loaded into Archikad, all structures and objects are placed on one layer, but I need them to be placed on different layers.
Hello.Is it possible to select objects on all floors, being on the plan of the 1st floor?For example, a table object is located on the first floor, and its copies are on subsequent floors, can I select all tables not from the 3d view, but on the plan?
Hello) Maybe you know how I can automatically insert a value into a script parameter from an Excel or txt file. For example, I have an area parameter in the script, and I need this value to be taken automatically from an Excel or txt file.Is there any command in the script t...
