Learn more
Hoa Tu
Help: Merge PLN file using API
I am trying to write an API which will merge in an external PLN or MOD file. After going through the "API Development Kit" documentation and examples, I couldn't find any clue on how to do this.
Any clue will be appreciated.
Thanks
Hoa
2 Replies 2
I have also been unable to find a simple way to do this. One way I thought of, although lengthy would be to:
save using ACAPI_Automate
open the mod file using ACAPI_Automate
get details of every element in the mod file using ACAPI_Element_GetNum and ACAPI_Element_Get
reopen the original file using ACAPI_Automate
create all the elements using ACAPI_Element_Create
I only use archiCAD 9. In version 10 there is elemet.drawing that may do this???
Thanks,
Adam
adambutler wrote:
Thanks,
Adam
Is there a smarter way to do this?
