Archicad C++ API
How can I get area and volume of element components
kolioi
I have a generic wall with default parameters. When I open the All Components Schedule there is a list of all components of this wall. How can I get the area and the volume as displayed in the screenshot? Didn't find any sample code in the examples.
6 REPLIES 6
Hi Kolioi,
I think you can get these values via ACAPI_Element_GetQuantities.
The composites member of the API_Quantities object should have exactly those values you are looking for.
Hope that helps,
Bernd
Automating Archicad with Add-Ons, GDL-Objects & Python Archi-XT.com
Hi Bernd,
This works for elements but not for their components.
In the above example I have a composite wall with 2 skins
Here is my code
GS::Array<API_Guid> elemList;
GS::GSErrCode err = ACAPI_Element_GetElemList(API_WallID, &elemList, APIFilt_In3D);
for (USize i = 0; i < elemList.GetSize(); i++) {
	API_Element element{};
	element.header.guid = elemList.Get(i);
	err = ACAPI_Element_Get(&element);
	if (!err) {
			GS::Array<API_ElemComponentID> elemComponents;
			err = ACAPI_Element_GetComponents(element.header.guid, elemComponents);
			for (const auto& comp : elemComponents) {
				API_QuantityPar params;
				API_Quantities quantities;
				API_QuantitiesMask mask;
				API_ElementQuantity quantity{};
				quantities.elements = &quantity;
				ACAPI_ELEMENT_QUANTITY_MASK_SETFULL(mask);
				ACAPI_ELEMENT_COMPOSITES_QUANTITY_MASK_SETFULL(mask);
				err = ACAPI_Element_GetQuantities(comp.componentID.componentGuid, &params, &quantities, &mask);
				ACAPI_ELEMENT_QUANTITIES_MASK_CLEAR(mask);
				ACAPI_ELEMENT_COMPOSITES_QUANTITY_MASK_CLEAR(mask);
and ACAPI_Element_GetQuantities() returns APIERR_BADID (Incorrect elemGuid was specified / The passed identifier is not a valid one, or valid, but not proper for the given operation). If I pass the wall guid, the function returns correct values for the wall. However, I want to obtain the area and volume of the wall skins.
I was thinking about getting the quantities for the element wall and then checking quantities->composites.
Did you try this too?
It's NULL
Hm... you probably need to allocate the composites member first, like you did for the elements member.
GS::Array<API_CompositeQuantity> compositeQuantities{};
quantities.composites = &compositeQuantities;
kolioi
OK, I found it in the examples.
Element_Test, Element_Snippets.cpp, Do_CalcQuantities()
