nishida_jp
How to Get Elements(Column/Beam/Object) touch/cross/near By Element
Please teach me
ArchiCAD25/VC++2019/c++14
get guid list from one element (Column/Beam/Object) to elements((Column/Beam/Object))
cannot function by my test
ACAPI_Element_GetCollisions
ACAPI_Element_GetConnectedElements
ACAPI_Element_GetRelations
1 Solution
Hiromichi Shinkawa
Unfortunately, as I know there is no API function that you can simply check touch/cross/near between elements.
You can use ACAPI_Element_GetRalations() to check between beams but not work for beam to object, for example.
Using solid operation functions can be a workaround for different types.
But for checking 'near', the only idea come to my mind is to get 3D element polygons and check the distance between polygons one by one by yourself.
HTH
Go to post
1 Reply 1
Hiromichi Shinkawa
HTH
