YONGWOO KIM
How to change floor plan cut definition?
I want to change floor cut plan using api.
But it's not work.
API_FloorPlanCutDefinition floorPlanCutDefinition;
GSErrCode testErr = ACAPI_Environment(APIEnv_GetPreferencesID, &floorPlanCutDefinition, (void*)APIPrefs_FloorPlanCutPlaneDef);
floorPlanCutDefinition.currCutLevel += 1;
testErr = ACAPI_SetPreferences(1, sizeof(API_FloorPlanCutDefinition), &floorPlanCutDefinition);
testErr is 0. But current cut level is not changed.
1 Solution
Hiromichi Shinkawa
Please try the following code on AC27(build5030) to see whether you can change the cur level.
HTH.
	GSErrCode err = NoError;
	API_FloorPlanCutDefinition prefs = {};
	err = ACAPI_ProjectSetting_GetPreferences( &prefs, APIPrefs_FloorPlanCutPlaneDef);
	if (err == NoError) {
		prefs.currCutLevel = newCutLevel;
		err = ACAPI_ProjectSetting_SetPreferences( &prefs, APIPrefs_FloorPlanCutPlaneDef);
Go to post
Hiromichi Shinkawa
HTH.
Hiromichi Shinkawa
If you feel this is a good solution, please hit that “Accept as Solution” button. This helps others quickly find the answers. Thank you!
