Tran Thanh Lo
How to get 2D Symbol and 3D Back View of object in ArchiCAD API?
Hello everyone,
Currently, I’m trying to retrieve information (such as the lines that form it or an image) for the following two attributes of an object using the ArchiCAD API:
  • 2D Symbol
  • 3D Back View
Does anyone know how to achieve this?
Thank you very much for reading my post!
1 Solution
Hiromichi Shinkawa
Hi, Could you check ACAPI_LibraryPart_ShapePrims() command? It's used to get object 2D drawing of symbol on floor plan and S/E view.
Unfortunately there is no examples code in API kit, but you can find similar code which is using ACAPI_DrawingPrimitive_ShapePrims().
HTH
Go to post
1 Reply 1
Hiromichi Shinkawa
HTH
