ā2025-01-20 02:26 AM - edited ā2025-01-20 09:32 AM
Hello.
I want to create morph from .xyz or .e57 file point cloud data.
Now, I create mesh with 'File -> Interoperability -> Place Mesh from Surveyors Data...' and convert mesh to morph.
But, this method only works for .xyz file.
I placed a point cloud library object using 'File -> Interoperability -> Import Point Clouds...', but I don't know how to convert it to a mesh.
I find this. Still unable to access point cloud points?
https://community.graphisoft.com/t5/Archicad-C-API/Point-Cloud-data-access-from-the-API/td-p/223481
How can I create mesh using .xyz or .e57 file?
Solved! Go to Solution.
ā2025-01-20 09:08 AM
One could use an external program called "cloudcompare" to convert e57 data.
Its free and powerful but needs some time to get into.
ā2025-01-20 03:23 PM
Point Clouds are not meshed, they are just that: Points.
If you want to get a mesh out of Point Clouds you need a third-party software, just like the mentioned Cloudcompare.
You could also try Rhino 8's new "ShrinkWrap" command.
ā2025-01-20 04:23 PM
If the xyz or e57 data is formatted correctly ArchiCAD can import it as terrain, thus convertiable as morph.
But this only works with terrain data, eg. no overhangs etc.
