How to get object geometry openings
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2025-06-27 01:55 PM
Hi I am trying to get object geometries using ArchiCAD API and convert them to .obj files but I couldn't get the openings on the walls. I only got whole geometry of a wall even if it have windows or doors placed on it. What I am missing? Any help is appreciated.
for (Int32 ibody = info3D.fbody; ibody <= info3D.lbody; ibody++) {
API_Component3D component = {};
component.header.typeID = API_BodyID;
component.header.index = ibody;
err = ACAPI_ModelAccess_GetComponent(&component);
if (err != NoError)
continue;
nVert = component.body.nVert;
nEdge = component.body.nEdge;
nPgon = component.body.nPgon;
// Collect vertices
std::vector<API_VertType> verts(nVert + 1);
for (j = 1; j <= nVert; j++) {
component.header.typeID = API_VertID;
component.header.index = j;
if (err == NoError) {
verts[j] = component.vert;
char buf[128];
snprintf(buf, sizeof(buf), "v %f %f %f\n", component.vert.x, component.vert.y, component.vert.z);
objContent += buf;
// Collect edges
std::vector<API_EdgeType> edges(nEdge + 1);
for (j = 1; j <= nEdge; j++) {
component.header.typeID = API_EdgeID;
edges[j] = component.edge;
// Write faces
for (j = 1; j <= nPgon; j++) {
component.header.typeID = API_PgonID;
if (err != NoError)
continue;
API_PgonType p = component.pgon;
// Collect all contours (outer + holes)
std::vector<std::vector<int>> contours;
std::vector<int> currentContour;
for (Int32 pedgIdx = p.fpedg; pedgIdx <= p.lpedg; ++pedgIdx) {
component.header.typeID = API_PedgID;
component.header.index = pedgIdx;
if (err != NoError) break;
API_PedgType pedg = component.pedg;
if (pedg.pedg == 0) {
// End of current contour, start a new one
if (!currentContour.empty())
contours.push_back(currentContour);
currentContour.clear();
continue;
Int32 edgeIdx = abs(pedg.pedg);
if (edgeIdx < 1 || edgeIdx > nEdge) continue;
const API_EdgeType& edge = edges[edgeIdx];
int vIdx = (pedg.pedg > 0) ? edge.vert1 : edge.vert2;
currentContour.push_back(vertexOffset + vIdx);
// Only export the outer contour (first one) as a face
if (!contours.empty() && contours[0].size() >= 3) {
const std::vector<int>& faceIndices = contours[0];
for (size_t k = 1; k + 1 < faceIndices.size(); ++k) {
char buf[128];
snprintf(buf, sizeof(buf), "f %d %d %d\n", faceIndices[0], faceIndices[k], faceIndices[k + 1]);
objContent += buf;
vertexOffset += nVert;
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2025-07-04
09:29 AM
2025-07-04
11:06 PM
Hi, I'd suggest you to try pass the window/door guid and call the following command:
HTH.
elemHead.guid = window_guid;
err = ACAPI_ModelAccess_Get3DInfo(elemHead, &info3D);
if (err) return;
for (Int32 i = info3D.fbody; i <= info3D.lbody; i++) {
API_Component3D component{};
component.header.index = i;
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2025-07-06 12:56 AM
Yes I am also putting window/door guids into that function and it gives me complete geometry of the object. However I cannot get the openings on the walls that have windows on it. I have a simple project with a wall and a windows on it. I can get the wall and windows using guids and Model_Access_API. But I cannot see the opening on the wall where the window should be. Is there a way to get that?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2025-07-07 06:25 AM
Hi, Maybe I'm not fully understand what you meant the opening. You cannot get the opening geometry only as it's represented by wall. I mean if you get the wall geometry, than you can a piece of wall with a hole (opening) geometry.
HTH.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2025-07-09 05:28 PM
I expect the wall should have a hole in its geometry representation where the window placed. But maybe I am thinking wrong.
