‎2016-12-12
09:32 PM
‎2023-07-12
09:02 PM
Doreena Deng
‎2016-12-14 09:10 AM
IanTr wrote:Hello Ian,
I'm new to Archicad and am looking into a bug whereby shell objects doesn't appear ( I suspect because there isn't an implementation to handle arcs/shell). The original implementer of our archicad codebase left so I'm picking up the pieces so to say.
From what I can tell, we are using ACPI_Goodies(API_RegularizePolyID) to triangulate Archicad primitives. I did fix the case for APIERR_IRREGULARPOLY by using API_RegularizedPolyID. However I'm still seeing error APIERR_REFUSEDPAR return by APIAny_TriangulatePolyID due to arc since the function only accept polygons w/o arc segments. I was just wondering if someone could point me towards tutorial/sample codes/ or how to go about triangulating arcs?
Thanks in advance,
Ian
‎2016-12-14 08:56 PM
‎2016-12-15 11:51 AM
IanTr wrote:You could facet the arc edges to the required level of precision first.
According to the API doc, ACAPI_Goodies (APIAny_TriangulatePolyID, ...) only accept polygons that has no arc segments. The code snippet on that page also shows it skips over nArcs > 0. I was just wondering if there are functions/methods that I missed looking through the samples that handles triangulation of arcs.
‎2016-12-18 11:40 AM
Ralph wrote:Ian,IanTr wrote:You could facet the arc edges to the required level of precision first.
#include "GenArc2DData.h"
#include "Ellipse2DData.h"
** Gets the current ARCHICAD settings for arc division **
static double GetMaxDiff ()
double maxDiff = EPS;
if (ACAPI_Environment (APIEnv_GetExportToleranceID, &maxDiff) != NoError) {
API_MagicWandInfo mwi = {0};
if (ACAPI_Environment (APIEnv_GetMagicWandSetsID, &mwi) != NoError)
maxDiff = EPS;
else
maxDiff = mwi.arcDiff;
return maxDiff;
** Divides an arc according to the currect AC settings **
static GSErrCode DivideArc (const API_Coord& orig, double r,
double begAng, double endAng, bool reflected,
double ratio, bool elliptic,
USize * nCo, Coord** hCo)
GenArc genArc;
if (elliptic) {
genArc.SetToEllipseArc (Geometry::Ellipse ((const Coord &)orig, r, ratio, 0.0), begAng, endAng, reflected);
} else {
genArc.SetToCircleArc ((const Coord &)orig, r, begAng, endAng, reflected);
Geometry::DivideEllArcToCo (genArc, GetMaxDiff (), hCo, nCo);
return NoError;
** Writes out a Circular/Elliptic Arc, divided **
static GSErrCode DWF_WrDividedArc (const API_Coord& orig, double r,
double begAng, double endAng, bool reflected = false,
double ratio = 1.0, bool elliptic = false)
USize nCo = 0;
Coord **hCo = reinterpret_cast<Coord **> (BMhAll (0));
GSErrCode lastErr = DivideArc (orig, r, begAng, endAng, reflected, ratio, elliptic, &nCo, hCo);
if (lastErr != NoError) {
BMhFree ((GSHandle) hCo);
return lastErr;
return lastErr;
Regards, Akos
