2023-10-13 06:02 AM
I hope my AddOn can be used in the schedule interface, it is gray now. 😞
I have tried these methods, without success.
Is there any other way?
2023-10-13 07:52 AM
Hi Luna,
I think there's actually no way to enable a menu command when you are in the schedule window. It's probably related to the issue, that we can't access schedules via the API anyway.
Best,
Bernd
2023-10-13 07:57 AM
Thank you, Bernd.
Is there any way to export the schedule I designed into Excel? Of course, through my AddOn, not the AC's built-in save function.
2023-10-13 08:09 AM
You could setup the schedule to be published in a publisher set (not sure if this can be done via the Add-On) and then save it with ACAPI_ProjectOperation_Publish.
2023-10-16 03:28 AM
Thanks, I still need some time to learn and try this method. 🙂
