luna
How to use AddOn in the schedule interface?
I hope my AddOn can be used in the schedule interface, it is gray now. 😞
I have tried these methods, without success.
Is there any other way?
4 Replies 4
Hi Luna,
I think there's actually no way to enable a menu command when you are in the schedule window. It's probably related to the issue, that we can't access schedules via the API anyway.
Best,
Bernd
Automating Archicad with Add-Ons, GDL-Objects & Python Archi-XT.com
luna
Thank you, Bernd.
Is there any way to export the schedule I designed into Excel? Of course, through my AddOn, not the AC's built-in save function.
You could setup the schedule to be published in a publisher set (not sure if this can be done via the Add-On) and then save it with ACAPI_ProjectOperation_Publish.
luna
Thanks, I still need some time to learn and try this method. 🙂
