We value your input!
Archicad C++ API
I am not finding compSlabID in attribute.
LeeJaeYoung
1. I can't find compSlabID in attribute.
I don't know why you thought slab had a profile ^^
element.wall.profileAttr
element.beamSegment.assemblySegmentData.profileAttr
element.columnSegment.assemblySegmentData.profileAttr
AC27 on window 11
LeeJaeYoung
I found that the composite slab ID is the same as the composite wall ID.
compSlabID = compWallID
AC27 on window 11
1 REPLY 1
LeeJaeYoung
AC27 on window 11
