2025-04-10 10:17 AM
I have some problem to get 'ExternalGlobalId' and 'GlobalId' in ArchiCAD28.
I want to get 'ExternalGlobalId', if there 'ExternalGlobalId' is exist.
And, if 'ExternalGlobalId' is not exist, I want to get 'GlobalId'.
An error occurs when exiting the for loop.
Occurs only when 'ExternalGlobalId' is not present.
In 'Microsoft Visual Studio\2019\Professional\VC\ToolsMSVC\14.29.30133\include\xmemory'.
0xC0000005: Access violation reading location 0xFFFFFFFFFFFFFFFF
This is my code.
for (int i = 0; i < selList.GetSize(); i++)
UniString ifcType = L"", ifcIdStr = L"";
API_Elem_Head elemHead;
elemHead.guid = selList[i].GetGuid();
ACAPI_Element_GetHeader(&elemHead);
auto objectID = IFCAPI::GetObjectAccessor().CreateElementObjectID(elemHead);
auto ifcTypeResult = IFCAPI::GetObjectAccessor().GetIFCType(objectID.Unwrap());
if (ifcTypeResult.IsOk())
ifcType = ifcTypeResult.Unwrap();
auto externalGlobalId(IFCAPI::GetObjectAccessor().GetExternalGlobalId(objectID.Unwrap()));
if (externalGlobalId.IsOk())
ifcIdStr = externalGlobalId.Unwrap();
else
auto globalId = IFCAPI::GetObjectAccessor().GetGlobalId(objectID.Unwrap());
if (globalId.IsOk())
ifcIdStr = globalId.Unwrap();
Solved! Go to Solution.
2025-05-15 08:40 AM
Hi
Does this occur with a Debug, or Release/RelWithDebInfo Add-On build?
I've seen stg. similar, when using a Debug AddOn with an Archicad release, while it worked with the Rel-Rel combination.
2025-05-15 08:40 AM
Hi
a month ago
It solved with Release.
However, is there any plan to fix it in the future?
a month ago
I had a similar issue a while ago. You can change your Debug build setup a little bit to get rid of the issue in Debug builds.
Graphisoft now discourages using ACAP_STATD.lib. Instead you should always link to ACAP_STAT.lib also in Debug build and set the ITERATOR_DEBUG_LEVEL=0. After changing these two things, I didn't have any issues anymore in debug mode and attaching a debugger works as well still.
More details here: https://community.graphisoft.com/t5/Archicad-C-API/Crash-for-GetOrganizationIds-in-DEBUG-builds-link...
